Thread: Change alternator belt on 1.9 150?
    Redcar
    Default Change alternator belt on 1.9 150?
    Hello guys finally fixed my EGR and damaged boost pipes now got a squeak from my Aux Belt :-( Is this easy to change and can i do it from the top? Thanks guys :-)
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    It's easily done, just a 5 minute job, but you'll have to jack the car up and do it underneath.
    Regular Member Craig1985's Avatar
    harwich essex
    Iirc I used a 15mm ring spanner on the bolt on the tensioner as you pull it back it will slacken the belt, the but doesn't actually come undone just pulls back? Could be slightly wrong tho as I last done it about 4 years ago on the 1.9cdti
    Engine : 1.9 CDTi
    I just remove the airbox, 15mm spanner onto the tensioner and pull it towards the front of the car (I think lol) then unhook the belt and change.
    Redcar
    So can I do it from top and just remove air box? Thanks for the help gents :-)
  1. New alternator and belt
    By Mark-R in forum Engine & Drivetrain
    Last Post: 14th September 2012, 17:20
  2. Alternator / AUX Belt Change - 1.9 150
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 17th November 2011, 23:47
  3. Alternator Belt Change - What a Palaver!
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 09:59
  4. Removing belt to change alternator
    By wali110 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 19:33
  5. Alternator Belt! HELP A.S.A.P
    By rwellfair in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 07:43
vectra 1.9 cdti alternator change www.vectra-c.com
vauxhall vectra 1.9 cdti alternator belt fitting
