Thread: Rear upper trailing arm bush's
    Regular Member punkgsi's Avatar
    Jul 2012
    sleaford
    Default Rear upper trailing arm bush's
    Hi just a quick one! Does anyone know if the outer trailing arm bush on a vectra b is the same as a vectra c because i bought some by mistake?
    11 Post(s)
    If you'r referring to the lower control arm, then no, the C ones are slightly bigger.
    EDIT - ignore, just saw the subject header says "upper arms"
    South east
    The answer is still no - the Vec-B shares no suspension parts with the C.
    Jul 2012
    sleaford
    Cool thanks rebellion,i have just bought a vectra b gsi on a 'Y' reg to have as play toy so at least they will come in handy for that...
  1. Best place to get rear trailing arms/banana arms??
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 09:53
  2. Rear suspension trailing upper control arms
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2011, 21:40
  3. rear wobble not shockers or trailing ams
    By sxigaspete in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 20:18
  4. Rear trailing arms
    By lizard in forum Handling & Braking
    Last Post: 13th September 2009, 18:07
  5. Upper Trailing Arms
    By Pete in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2009, 23:25
vectra c rear trailing arm bush
vectra c outer trailing arm bush
