Thread: 3.2 GSI idle
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default 3.2 GSI idle
    Hi all my gsi has a little splutter at idle anyone know what this could be?
    Sent from my iPhone using Forum Runner
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Could be the throttle body mate. A breather hose goes to it from the crankcase and they get crapped up. Take the hose off that goes from the AFM to the throttle body and have a look inside. If it needs cleaning then its easy enough to remove, just 3 bolts and a couple of pipes. There is a how 2 somewhere i think. Make sure you also clean the breather pipe out too while youre at it. Only other possible cause is a faulty coil pack, My old Vec B had a rough idle once and that was a faulty rcoil pack on the rear bank HTH
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Thanks mate will have a look at it today
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Ok ive had a look what pipe is the breather lol i took it off and noticed one of the bolts holes is rounded off so the bolt isnt tightening up and there was no gasket :S so when i put it back together after a clean i put gasket sealant on it just now it seams to be a bit better i think will find out once its heated up better.
    Derbyshire
    6 Post(s)
    Breather pipe is arrowed in the pic. It goes under the inlet and round to the back of the engine......
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Thanks that was a little clogged up but not to bad but cleaned it up anyway lol
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    where does the air pipe go from the t - piece on the other side of the engine , runs underneath the covers , does it end up on the manifold [inlet]
    looking for an air-leak on mine
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    That pipe goes right along the front of the engine and down the right hand side if your looking at it head on.
  1. dti idle
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th October 2012, 01:32
  2. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  3. Idle on a 2.2 Sri
    By chilljohn in forum Engine & Drivetrain
    Last Post: 6th February 2009, 22:57
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. 3.2 gsi at idle
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2007, 19:26
