Results 1 to 10 of 28
Thread: Error codes. Anyone kind enough to advise?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Error codes. Anyone kind enough to advise?
    B1000-39 unknown code
    P0621-02 unknown code
    P1901-75 particulate filter pressure sensor high differential pressure
    P0002-52 rail pressure control range/performance
    What need doing, cost and how long it would take to do. Bearing in mind i'll be doing it myself as in saving costs and gaining experience for myself and helping hands.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Anyone???
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Humourbash View Post
    Anyone???
    B1000 I think is the SDM (airbag control unit) - could be loose cables/connectors under the seat.
    P0621 - Generator Field "F" Control Circuit Malfunction - could be alternator/battery issue, might be worth checking the volts on the battery engine running/not.
    As for the others, do you have any issues currently with the car? What is the car, CDTi? Auto/Manual?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    1.9cdti 150 z19dth engine. Goes limp mode 2 minutes after starting and driving. Use excessive fuel, 10-30% than it should. Was half tank yesterday but 30 miles of easy driving, its now 1 bar away from red zone where before would be using half a bar for 30 miles urban!
    Turbo dont tick on when limp goes on meaning excessive fuel burning too much? Turbo replaced, maf checked. Egr cleaned, tbc cleaned, clueless now!!
    Lancashire
    Trim : XP1
    Mileage : 66000
    Is it an Estate or an Auto? Basically wondering if it has a DPF, if so this could be the cause of the problem, i.e. blocked or in need of a re-gen.
    EDIT: Just checked your profile, its an estate and will have a DPF, have you had this checked out?
    Jul 2010
    Nottingham
    I had the same code P1901-75 particulate filter pressure sensor high differential pressure, same symptoms as yourself, light on every two miles then limp home mode,I cleaned the dpf filter and now its back to normal.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by daz_scooby@hotmail.c View Post
    Yeah keeps going in limp mode so quickly turn off then on to resume normal driving behaviour til limp mode 2 minutes later!! Annoying tho!
    What should i do with this stupid dpf?? The easiest method please.
    As for the fuel rail. What is this??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    No didnt check out but what should i do??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Any one know where to get cheapest dpf?? Ebay is at £270! A bit out of my reach!! :-(
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Double post.
  1. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  2. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  3. Error codes, 2.2
    By Rennie in forum Engine & Drivetrain
    Last Post: 10th April 2010, 23:21
  4. Need Some Help...Vec-B Error Codes
    By Vaux-Man-G in forum General Chat
    Last Post: 9th April 2009, 08:56
  5. Hello All..... I'm after your help (ERROR CODES)!!!
    By albertoleach in forum Introduce yourself.
    Last Post: 9th March 2009, 09:50
