Thread: Oil change
    Jul 2011
    UK
    Year : 06
    Default Oil change
    My car is over due a oil change cdti 150 what oil do I use how much is genuine oil and how much should I use also will I need to replace the sump plug and washer thanks
    Nov 2009
    Warrington
    Quote Originally Posted by marc vectra sri View Post
    i get mine from autovaux. I think the oil is £19 for 5ltr you'll need 4.3ltr and oil filter was about £6 I think. I did replace my sump plug washer last time but can't remember how much it was. did an oil change on my 1.9 150 last week.
    Aug 2010
    Derbyshire
    As above, a 5 litre bottle will do your oil change. Get 5w-30 GM full synthetic.
    I didn't change my plug/washer and no problems. You may want to get a plug/washer anyway because sometimes they can get mullered removing them. Depends who tightened them up before.
    If doing the job on your drive rather than a ramp, you will find it easier to remove the undertray completly. That service flap is a PITA as you can't get the car high enough on a jack/stands to get it down enough for access. You need a 34mm socket/filter removal tool for the filter housing.
    Mick
    Jul 2011
    UK
    Year : 06
    Thanks lads will be doing it on the drive on ramps so should get good height but will remove the whole tray
    Nov 2009
    Warrington
    it's a 32mm socket you need for the filter, I did it on my drive no problem on axle stands and yeah forgot to say it was 5w 30
    Aug 2010
    Derbyshire
    Quote Originally Posted by rob warrington View Post
    Whoops sorry for the miss info about the size of socket, it's an age thing remembering
    Mick
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
