Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: vxr stick fitting last shout
    Regular Member mrk's Avatar
    14:88 our time will come
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default vxr stick fitting last shout
    fitting it fri afternoon just unsure about splitting the balljoint as i dont want to knacker it when splitting .the how to says to use 2 screw drivers is this to pry the joint apart?
    cheers mrk
    Full Member
    South West
    Very easy mate. I used one quite long flat blade screwdriver. Just get it between the ball and the joint and it will pop off. Take your time and its a very easy job to do mate. I am mechanically inept but managed it!!
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by mrk
    cheers mrk
    Mate no splitting needed basically pop up the gaitor then lift it up round ya gear stick. Then looking down ul see 4 torx screws undo those leave 2 in place slack now reach down to the top right ul see the cable with a clip just unclip that and it will disconnect now take the over 2 torx screw out and the whole gear stick will pop out nothing needs forced no screw drivers just lift it up/out took me ten mins to change over To a astra one
    Trim : improving
    Year : 06
    one says split one says not omg still unsure
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    watch when you are doing the clips as there easy snapped.
    Is you're car a 6speed or 5 speed
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by mrk View Post
    You split the housing what holds the ball joint in place
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Mark-R
    Nope ya don't lol only do this if the gear stick u have hasn't got the housin most should or ur fitting a 6 speed into a 5
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    all this talk of splitting knobs, ball joints etc sounds very painfull to me.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by marc vectra sri View Post
    If you dont split it its is going to be a c*nt of a job getting to them torx screws i just did mine and i replaced the full stick and housing and i had to take out the full center consul from the arm rest right to the section around the gear stick as there was no way of getting a torx socked down that space (i tried lol)
    Jul 2011
    UK
    Year : 06
    What engine do u have mate I basically got a torx screw driver to the screws and took them off unclip the cable and it came straight out took ten min to put another gear stick in
  1. Fitting Astra VXR gear stick on a Vectra C
    By danny_n in forum Styling
    Last Post: 6th August 2012, 19:44
  2. big shout out.
    By littlegreenmartian in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2012, 22:21
  3. help fitting Zafira Vxr gear stick
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 22:48
  4. newby shout
    By vectra 8v turbo in forum Introduce yourself.
    Last Post: 4th September 2008, 12:39
