Thread: Knocking front and back
    Jan 2008
    ireland
    Default Knocking front and back
    Hi chaps,
    had a look over the car, and seem to have knocking front and back, any advice or help greatly appreciated,
    seems like the bushings are flaking on the front ARB on both sides, the right (drivers side) drop link can be moved freely with no load on the shock, i wonder is this normal?
    with the rear i have some pictures and i wonder is the knocking caused here... the rubber bushing in the uca's seem to be perfect, also the below seem to be relatively new!!
    unfortunately the rubber that did exist in the below image seems to have completely eroded, would this cause the knocking? i forgot to check my rARB (if i have one), my rear shocks seem solid but the rubber on the bottom of one seems "burst".
    any and all help, advice appreciated,
    regards Dave.
    Jan 2008
    ireland
    bump, just wanna purchase few parts before next week
    South east
    For the rear, you've stated that the UCA bushes seem to be perfect. Is that from looking at them? There's usually no visual indication of wear, you need to undo the outer bolt, lift the end of the UCA clear of the hub assembly, push a long screwdriver through the hole and tilt the bush up and down - there should be good resistance and a smooth movement. With worn bushes it will be too easy to move the inner part of the bush. Less commonly, it can be excessively hard to move it because it's gone almost solid. Either of those scenarios means you need to change them because they're the cause of the noise. The rear lower bush you've shown a photo of isn't the cause - everyone's looks like that.
    Jan 2008
    ireland
    very helpful information there Rebellion, thanks a million! i have the double bushings on my roll bars which seem to be very solid so it cant seem to be those, i think ill get the uca's for the rear and links for the front, fit em and go from there, my springs are in great condition rear and front so ill leave them. thanks again
    Dave
    Last edited by unreal_event_horizon; 30th September 2012 at 15:59. Reason: extra info
  1. Knocking from n/s front
    Last Post: 12th April 2012, 10:54
  2. knocking from back wheel
    By Linz-t- in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 17:53
  3. Knocking at Front......... Help
    By johnny1983 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2012, 17:46
  4. Knocking from front
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2011, 18:51
  5. Knocking from the front
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 26th March 2011, 23:13
