Thread: How do I connect this stereo to my Vectra C?
    Jun 2011
    Burnley
    Engine : 1.9 cdti
    confused How do I connect this stereo to my Vectra C?
    I've recently purchased a new stereo on Fleabay. Absolute bargain, brand new, never heard of it!
    I have no Idea how to wire it in!
    It's a Car Video CDMP3 model MG012B.
    If any one has any knowledge of this system and how I could install it I would be very grateful!!
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Easiest way is to buy the facia and wiring harness adaptors, then buy a spare set of female iso connectors and wire the radio wires into the iso block, some radios may have a wiring diagram on the chassis of the unit. You can have it installed at a car audio shop but they will charge labour to fit it, other than that is buy a unit with the correct iso connectors to start with
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    That's going to take more than a wiring adaptor, the wiring there has a ATX computer power supply connection on it! It would be easier to make your own plug up instead. Tbh if you really want to keep the radio, take it to a proper audio shop and get them to fit it. That's not standard wiring there.
    Full Member Robsey's Avatar
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Okay I have had a look -
    You are running a Full CAN Vectra-C with a CDTi engine.
    The connector in the image is the radio's own connector, and the loom has plain ends (no connectors).
    So you can disregard the "ATX special wiring comment).
    I would get an SOT122S or an ISO2CAR conversion loom, available from the bay of e, or you can pay twice as much from Halfords.
    Your aerial will need a Fakra to ISO converter.
    Now then wire colours -
    On after market head-units, the yellow is permanent live, and the red is the ignition live
    (Vauxhall is red for permanent live, and black for ignition live)
    You will need to take your black from the lighter socket.
    Note - your head-unit is connected via a Quadlock connector,NOT ISO.
    From your Quadlock connector -
    RED - Battery live is on pin 15
    Ground - Brown is on pin 12
    There is a white sticker on the top of your original CD30, CDC40, CD70 head-unit, which will tell you what the speaker colours and pins are.
    If you need illumination, then take a link to the grey/yellow wire on the lighter socket or if you have a charge socket, then there should be a grey/yellow wire on a socket tied up out of the way near to the ashtray or below the hand-brake.
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    you just need an iso connector and and connect the same colors and connect to the car it will be fine. You also will need a facia to fit the unit.
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    It is a full CAN, so not an ISO connector -
    Car is a late 2004 fitted with a CDTi engine.
    All cars with CDTi are Full CAN. - Therefore Quadlock connector.
    Half-CAN's are quoted with DTi's.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    It appears now I've opened my eyes I can see that the wires in the picture are not going into the radio, the connector will actually plug into the back of the radio.
    Time for a visit to Specsavers I think.
    It is still an ATX plug though!
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by cont1204 View Post
    Either that, or put more water with it - "hic!!"
    A lot of aftermarket radio manufacturers will use readily available connectors, rather than pay for the design and manufacture of bespoke plugs. - Just good business sense.
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    By the way -
    If you need more wiring info, then simply PM me, and I can answer many queries as they affect your particular set-up.
  1. vectra stereo
    By merrick46 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 00:15
  2. Is it possible to wire connect an Ipod to the standard stereo?
    By Rik N.I. in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2008, 16:02
  3. is it possible to connect a quadlock sterio to a early iso vectra c
    By scunner in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 17:19
  4. Vectra C stereo? Is there any AUX in?
    By zsh in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2005, 10:05
vectra c stereo wiring diagram
what color is the stereo permanent live on a vectra c
lave om fra iso til quadlock vectra c 2004
vauxhall vectra c wiring diagram stereo
vectra c iso wiring
car stereo plain wires corsa c
vectra 1.9cdti stereo colours
vectra c radio wiring diagram
how do you wire a 2005 vectra radio into a 2003 vectra
vectra wires for aftermarket
which wiring harness for vectra 2006 stereo
vauxhall vectra stereo wiring diagram
where is the ignition live on a vectra for a stereo
