Thread: steering advice
    Regular Member jsnlvxr's Avatar
    wiltshire
    Default steering advice
    hi guys. im going to be doing a bit of a overhaul on my siggy as its just done 100k and feeling a bit tired. im going for the b12 set up to liven up yhe handling but whilst im doin this what would i need to do to tighten the steering as there seems to be a fair bit of play in the steering.just doesnt feel as sharp as it used to!! thanks guys
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Check for play in any bushes/arms/balljoints an replace as nesecerry, Also check for rubber bushes that have went 'soft'
    then after all the work is carried out check tyre pressures and get it 4 wheel aligned
    You will love the b12 setup!
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    track rod ends, wishobones, droplinks on the front, that shoud tighen your steering right up, and as said tyre pressures and a wheel alignment.
    wiltshire
    ok great thanks. i will get these bits together. ive got the arb bushes ready as they are squelching!
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Replies: 6
    Last Post: 13th March 2011, 10:47
  4. Advice Needed - Steering Wheel Vibration
    By Fozman in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2010, 22:48
  5. steering controls...advice needed
    By vectra666 in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2009, 18:12
