Thread: 2.2 dti injector seals
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default 2.2 dti injector seals
    hi all.
    the cars not been starting so well lately and iv been told to replace the leak off pipes which i have done.
    my mechanic mate is now telling me that i need the injector seals doing and im a bit skeptical.
    he says i have "black oil" coming out of the leak off pipes and its full of it at the bottom of the diesel filter?
    i seem to think that the soot has been mixing with diesel and settled in the filter but thats just a theory.
    so what are the symptoms i should be looking out for, for potential injector seal failure.
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    anyone know?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Your mechanic has diagnosed the fault correctly.
    The upper rubber seals (usually the worn ones) can be replaced without removing the camshaft completely.
    If you have soot in the diesel (as you seem to think) someone's seriously messed up your pipework under the bonnet.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    as said , oil in the fuel filter will be a sure sign of injector seals .
  1. Injector seals 2.0 Dti
    By bigmac in forum Engine & Drivetrain
    Last Post: 9th October 2010, 09:32
  2. Could this be injector seals or??
    By gmclorn in forum Troubleshooting
    Last Post: 18th February 2010, 14:06
  3. Injector seals
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 22:02
  4. Injector seals!!
    By siz1 in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:20
  5. injector seals
    By tditony in forum Troubleshooting
    Last Post: 6th May 2009, 20:10
vauxhall signum 2.2 injector seals
vectra 1.9 cdti injector seals www.vectra-c.com
2.2dti injector seals
2.0dti injectors vs 2.2dti injectors
