Thread: Tyre wear duration question...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Tyre wear duration question...
    I had on my rear tyres quite bad uneven wear on the inside edge of the tyres, random blocks were notably higher than others causing a small vibration and a droning noise, this was put down to the shocks (1 was defo failing) so these were changed about 600 miles ago now. Prior to changing them I put a part worn tyre on the back to quieten it off, and also to prove that was the issue (so it didn't do the same to new tyres).
    My question is, after the 600 (or so miles) the part worn tyres is showing no signs of the same stepped wear, it safe to say its now sorted, or would it take more miles than that to show on a tyre..?
    I want to replace both rears, and want to make sure they suffer the same issue.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Sounds like a camber problem, would get it aligned, The tyre tread design will have an effect on how it wears too, I think older michelins were bad for uneven wear and causing a droning noise.
    The rear tyres should not become marked from excessive wear until about 12K miles
    Once they have been on the rear for in excessive of 20K miles I would expect to see issues that would be noticeable
    However it really depends on how bad the incorrect alignment is
    If it is vastly incorrect it could be as little as 1500 miles before the rear tyres are damaged from the excessive wear, and that would be a serious issue that needs resolving
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    can the camber be adjusted on the rears?? mines are a bit out also.
    South east
    Yes, it can be adjusted a little.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    there is bolt you can get from the front to adjust the camber u think u can get one for the rear too??
    Dec 2010
    Glasgow
    Mileage : Near 100K
    The vectras already have that bolt fitted
  1. tyre wear
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2012, 19:02
  2. Tyre wear causes?
    By weverall in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2012, 20:46
  3. Tyre wear
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2011, 00:02
  4. HELP Tyre wear
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 09:14
  5. outside tyre wear
    By whatthevecisup in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2008, 21:17
