Thread: plz help water in passenger and rear
    Banned for Being a Numpty
    Jun 2012
    Default plz help water in passenger and rear
    any help on this went out to put my new born in car and it was full of water,need it sorted asap for me for me lil girl
    parked on slight hill facing up so water in back could of run to the back...is it the common pollen filter i hope its easy fix as my new arrival will be keepin me occupied...
    Chelmsford
    9 times out of 10 it's the drain just in front of the windscreen...
    Open the bonnet and make sure it's completely clear of crud (leaves etc)
    Aug 2010
    Leeds
    The drain under the pollen filter check that is not blocked.
    Jul 2011
    teesside
    Engine : Z18XER
    Jun 2012
    it was abit blocked but filters dry?
    Regular Member buffallobill's Avatar
    Jul 2009
    barnoldswick
    Quote Originally Posted by vectraross View Post
    just done mine today . filter dry, but plenty of water above drain scuttle. also cleaned out the round rubber drain tube on drivers side, now to dry the passenger side front and rear..carpet..
    Jun 2012
    any idears on that tried news paper and morrissons (NON) wet vac woopsie
    Jul 2009
    barnoldswick
    backed the car up on a small set of ramps, front of car pointing down hill. took the left side plastic facia off which is down at the foot well. (2 screws)
    lifted plastic that runs along the top of inside sill, careful wires behind it, lifted carpet and soaked approx 50mm of water up, then squeezed the front foam and rubber that fits to the bulk head in the passenger foot well. this is foam and holds water, and mopped up excess whilst squeezing. hope fully should start drying out now..
    Jun 2012
    i found the problem....passenger side rubber bung that the loom passes through had lodged allowing water to come in,with the recent floods its been cuming in,so popped it back in and black siliconed around it....now im goin to have to strip car out seats n that to get it all
  1. water in passenger footwell
    By brynsueg in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:25
  2. Water in Drivers side passenger (rear) footwell.
    By firemanshrek in forum Bodywork & Interior
    Last Post: 25th September 2012, 14:39
  3. Water in (rear) passenger footwell
    By shoeless79 in forum Bodywork & Interior
    Last Post: 19th March 2010, 00:57
  4. There’s water in the passenger foot well
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 22:36
