Results 1 to 10 of 14
Thread: Fault Code Help
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default Fault Code Help
    I went out and tried the pedal test on my Z30DT and i'm coming up with codes
    P0638
    P0400
    P1900
    if anybody could tell me what these actually mean.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Can't help on the others without looking them up but p0400 is egr flow malfunction
    Oct 2010
    Lincoln
    P0638 looks like Throttle Sensor
    Dec 2011
    Seaham
    Regular Member C-Owner's Avatar
    May 2011
    South London
    P1900
    Can be a generic code produced by the other faults.
    But
    IIRC on the V6 it's due to interrupted DPF re-gens if fitted.
    Sounds like the car needs an Italian tune up ================
    Limavady, N.I
    Mileage : 121000
    How do I get her to do a regen, I drove about 13miles home tonight at 70mph in 4th @ 3000rpm but as soon as I slowed down to turn in at a junction she went into limp mode again. There was also a new egr valve fitted last week.which I thought would help as the last that was the fault that was showing.
    Dec 2011
    Seaham
    Can you force a regen with Tech 2 etc?
    Limavady, N.I
    Mileage : 121000
    I'm hoping to get tech2 plugged in within the next week
    Limavady, N.I
    Mileage : 121000
    I have a couple of questions....Are the DPF cleaners any good?How much would a new DPF cost?And can you get a DPF bypass pipe for the Z30DT?
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    You won't need new DPF but their usually in region of £800
    the cleaners are more of gimic.
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
