Thread: Cleaning caliper carrier
    Chelmsford
    Default Cleaning caliper carrier
    Anyone give their caliper carrier bracket a scrub with the wire brush when changing pads?
    Just curious as I've been having a load of trouble with a rubbing noise when turning right since I changed the discs and pads on the front.
    Found an article online about how corrosion on the carrier can stop the outer pads to stick against the disc when the brakes are released and was wondering if this could cause the VERY annoying rubbing I'm suffering from!
    Also, has anyone ever suffered from excessive wear on the rubber sleeves which take the caliper slide pins? Also been wondering if they can get worn out and cause the caliper to move excessively and rub...
    Cheers!
    South east
    Do the pads even touch the carriers?
    Quote Originally Posted by DNS View Post
    It is ESSENTIAL when replacing the front pads and/or discs on the 314 mm setup
    I pointed this out to the local garage I used, they weren't aware of this when fitting the new front pads last time, but they know about this time (the mechanic asked me about this today, as he remembered I pointed it out last time)
    Nov 2009
    newcastle
    Giv a scrub but get a slider kit from vx to replace old
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Cheers!
    Had the same problem but when i was turning left took me a week to find out what i had done wrong,had wheels off dressed discs,pads out again checked everything over and over,eventually found i had routed the cable for the pad wear sensor wrongly and every time i turned the wheels it rubbed on the inner wall of the front tyre,only found it by chance as it wore through the outer insulation and was revealing a yellow wire inside,i know it sounds silly but it did sound like quite a harsh rubbing sound,might be worth a look
    Quote Originally Posted by geordieric View Post
    Why do you need to.replace the old sliders
    They run inside a rubber sleeve
    All you need to do is remove them clean them and cover in copper grease and remove the rubber sleeves and do the same to them and the hole the rubber sleeve fits in
    Buying new ones is a waste of money
    Sent from my GT-I9300 using Forum Runner
    Quote Originally Posted by marktaylor View Post
    I was told that using copper grease for the sliders is the wrong stuff to use.
    White lithium grease is the stuff you want.
    Aug 2010
    Leeds
    Replacing sliders ermmmm.
    Starting to think back to the mk2 cavalier and astra with those rubbish sliders that used to seize with them metal caps. Please has the vectra moved on i hope so!
    Mine are not even 50% worn yet at 26k.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You use a garage that doesn't know to clean caliper carrier with a wire brush?
    Surely you'd be questioning letting them work on your car?
  1. caliper carrier bolts
    By maximus1267 in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2016, 16:39
  2. Caliper carrier bolts - still can't get them
    By shchuka in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2012, 14:45
  3. caliper carrier bolts
    By trickyjacks.4 in forum Handling & Braking
    Last Post: 19th August 2011, 16:48
  4. Caliper carrier question
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 17:42
  5. Quick q.... Which way do the caliper carrier....
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2009, 14:56
