Thread: Vectra C auto Transmission Identification
    Sep 2012
    Australia
    Default Vectra C auto Transmission Identification
    I am about to put a second hand transmission into my car, however, I am told I have to match
    up all the ID numbers, or it wont run
    Which numbers do I need to match up, and which numbers dont matter?
    The car is a Vectra C 3.2 V6
    The box ID plate reads
    AF33 TW
    W-A03006882TW
    55352
    535A
    serial:03MV730068
    The box I want to use is all the same except for
    W-A04001446TW
    serial:04FV730830
    Thanks!
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    I can help you if you post your car's VIN number and the donor's VIN number.
    Sep 2012
    Australia
    Default Vectra C Transmission Identification
    Quote Originally Posted by Lao View Post
    The donor cars VIN is WOLOZCF6851025457
    My VIN is WOLOZCF6848089991
    Thanks!
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    There is something wrong with the donor's VIN number.
    Your car definitely has AF33, but I can't see the other VIN. Please check it out.
    Sep 2012
    Australia
    The donor VIN is correct
    WOLOZCF6851025457
    tripple checked it
    its a January 2005 3.2 ZC Vectra in Australia
    Thanks for your help.
    Sep 2012
    Australia
    I am buying a good second hand 5 speed trans to replace my water damaged one. (CDXi V6 3.2)
    My original box is a 55352 TW AF33.
    I have found another one exactly the same, reasonable price, but higher mileage then I would like.
    I have been advised that I can also use JG YES and TK boxes, as long as they are 55352.
    Does someone know for sure if this is true?
    I have the option of another box that has lost its ID plate, but I know it is a TK box from a nearly identical car as mine. I dont know if it is a 55352 or not.
    Does anyone know if the prefacelift 3.2 V6 CDX vectras had anything other than 55352 boxes?
    Sep 2012
    Australia
    Does anyone know if the 2005 3.2 V6 CDX vectras had anything other than 55352 boxes?
  1. Changing Auto Transmission Oil
    By dae36 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2016, 16:43
  2. Auto transmission starter motor
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 13:41
  3. Auto transmission dipstick....
    By bigmac22 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 01:34
  4. '03 Signum V6 auto transmission problem
    By Arnie in forum Engine & Drivetrain
    Last Post: 8th June 2009, 20:00
  5. Engine `spanner' light + auto transmission problem
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2007, 21:38
where can i find the transmission dipstick on vectra c
