Thread: M32 bolts
    Sep 2012
    Notts
    Default M32 bolts
    Good morning good people.
    I'm in the process of changing my clutch/dmf on my 1.9 cdti Vectra C a la tugger434's most excellent 'how to'.
    It's a z19dt engine with m32 gearbox not f40 though but that has mattered little up to yet. I'm at the part where I'm removing the gearbox bolts so that I can split it away from the engine. Now on the 'how to' it says remove 6 bolts, I've taken 5 out and for the life of me can't see any more but neither will the engine/gearbox split.
    Any suggestions would be most welcome........
    Sep 2012
    Notts
    Found it!! Tucked away under the starter motor. Couldn't actually see it, had to get it out by feel only...... don't remember the clutch being this hard last time I changed one ( Mk2 Cortina 1600 )
    Anyway gearbox now out, tomorrow's another day......
    hull
    sorry to ask mate but how do you know its a m32 box, mines a 57 reg cdti120 and the sticker on the cam cover tells me nothing???
    Sep 2012
    Notts
    frasedeb... sory for not responding sooner been busy.
    I couldn't tell either, no sticker and no stamp anywhere on the box that meant anything I had to go with what the stealership that's had it in the past told me and trust them.
    Once it's off it is then easy to tell and fortunately they were right as I'd already bought the new clutch kit.
    Anyway, on M32 box's the input drive shaft has 20 splines on the F40 it has 23. There's a pdf document on the web somewhere put out by LUK, a quick google search should find it easily enough.
    Latest news is I can't get t he flywheel bolts out!! They're t60 torx and tight as a drum, I'm just not strong enough with the leverage I can get...... ( ******, thinking cap on ).
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    I had same problem had to get a electric impact wrench then took a few seconds to undo them
    Sep 2012
    Notts
    That's a good suggestion
    Just had a quick look at local tool hire, £37 a day ( boo hoo ) :-(
  1. For Sale: 4 x10mm spacers, spigots, longer bolts and locking bolts
    By 6009tristanb in forum Parts for sale
    Last Post: 25th September 2011, 20:02
  2. bolts
    By brant2474 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2007, 21:27
  3. Spare Wheel Bolts From Locking Wheel Bolts
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2007, 16:55
