Thread: Is there wiring in the boot of a signum for a power outlet?
    Nov 2010
    Maidstone
    Default Is there wiring in the boot of a signum for a power outlet?
    Would be handy to have one, was just wondering if there is likely to be wiring sitting about for a socket and where i should be looking?
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by signum_rob View Post
    http://www.vectra-c.com/forum/showthread.php?t=137128
    Nov 2010
    Maidstone
    I was thinking something along the lines of plug and play, if it involves more wiring being added i might give a miss.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    It might be there.. on the estate its plug and play.
    scottish region
    if you look behind the side trims the plug could be there mate
    South east
    There are two empty slots in the Signum's boot fusebox - one is live-with-ignition-on, and one is permanently live. Since you're not going to plug your electrical product directly into a fuse slot, you will obviously have to do a little wiring work to connect the item to the fuse slot.
    Nov 2010
    Maidstone
    I was just wondering if anyone had a signum with one from factory and where it sits in the side trims? Just so i dont scour the boot for wiring that might be hidden well.
    South east
    Nothing like that is fitted at the factory.
  1. installing a power-outlet/cig lighter rear passengers
    By tinus71 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 09:25
  2. does a vectra design facelift have a power outlet in the boot?
    By smiley32 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 20:18
