Results 1 to 10 of 20
Thread: 3rd brake light
    North West
    Default 3rd brake light
    How do i change the 3rd brake light from RED to CLEAR to match my new rear light clusters
    I have seen many cars wwith the clear colour and i think it looks nicer
    Cheers & Happy New Year 2007 to Everyone who drives a Vectra
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I would guess you simply need to buy the clear cover from Vauxhall ... the Elite has a clear cover so they shouldn't be difficult to get hold of:
    Dave
    Hertfordshire
    Easy enough to do, but I think you'll find you need to change the whole light unit, as the lense is all part of it.
    If you have a look in the part numbers sections here, you'll find the part number, lol.
    North West
    thanx i got the part number hopefully i can fit it myself.
    anyone ouit there changed there 3rd brake light can give us some advice
    thankx for the picture too,mine is silver-lightning so the clear matches well
    Hertfordshire
    I've not done one, but I expect you start by taking the interior trim panel off the tailgate and having a look see in there, probably find it plugs in electrical wise and is held in by just a couple of screws/nuts.
    Jul 2006
    Cheshire
    I had one complete unit changed on my last vectra and it took the technican about 15 minutes ... IIRC the inner boot trim comes out (press in studs around the edge - small flat blade screw driver slides in small hole and the middle pops out of the stud after which it can be removed) and then it's basically clips and and a clip on connector wire.
    Good luck!
    Dave
    Jul 2006
    Cheshire
    Quote Originally Posted by Silver Vectra C View Post
    I think it looks good on a black one too
    North West
    Its sure does Black and Silver are the best colours and match almost anything
    Thanks 4 all the advice,i am going to have a go at fitting it
    Regular Member breezephil's Avatar
    LONDON
    Interesting - I might have to have a Go at that - I have a Clear one already on the Breeze but it has a crack in it so... out it comes I think.
    Feb 2007
    Kent
    Hi, can anyone that has done this swap advise on how to fully remove the interior hatch trim? I removed four black plugs and two torx screws but it still held fast. Prising up the corner there appear to be white lugs and housings at each corner but I can't see how to slide it to one side or the other. Light was failing so buttoned her up again and will take another look tomorrow.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Brake light
    By mambo in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2010, 01:36
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
how to replace third brake light vectra c
how to change the 3rd brake light on a vauxhall vectra
