Results 1 to 3 of 3
Thread: Leaking oil :(
    Jul 2012
    N.Ireland
    Vehicle : Vectra C 1.9CDTi
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 130k
    Default Leaking oil :(
    Hi folks,
    my CDTI 120 8v seems to have a slight oil leak from the are in the photos below
    The first picture is a top down view and the leak is underneath the join of that big pipe running right. The second picture is taken closer in from the passenger side of the engine.
    Firstly, name that part as I haven't a baldy.
    Secondly, how bad is this?
    I've had the car since Feb and it's running fairly well, only thing I would say is that there is a puff of white smoke on start up from cold ..... other than that I have no issue with the car.
    Any help/info is much appreciated Thanks
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    first pic is the turbo pipe from inter cooler to inlet manifold. the second looks like the throttle body. its common for them to leak a bit of oil their as the oil breather goes into the inlet manifold.
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 130k
    Quote Originally Posted by dan danz View Post
    Ok, first pic was just to give an idea of where on the engine the affected area is .... it's below where the turbo pipe starts there. The second pic is the affected area from the side, directly below the join of the turbo pipe.
    So it's not a major issue and is common enough? It's not a lot of oil and the car isn't drinking oil.
  1. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
  2. oil leaking...
    By danman487 in forum Engine & Drivetrain
    Last Post: 6th September 2010, 08:01
  3. Rad leaking
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 20:16
  4. air con leaking
    By nicademus in forum Bodywork & Interior
    Last Post: 7th July 2010, 22:11
  5. leaking air con
    By baz2003uk in forum Engine & Drivetrain
    Last Post: 19th June 2010, 23:38
