Results 1 to 10 of 16
Thread: key fob won't resync.
    Regular Member vegasbaby's Avatar
    BARNSTAPLE
    Default key fob won't resync.
    Hi guys, hopefully someone will be able to sort my key prob........ I would have to get nearer and nearer to the car for the fob to work, so I thought maybe the battery was getting low, so I changed it. I changed it straight away, as I know you only have a set time to do it. I went back out to the car and tried it....nothing. It will let me open the car, and the alarm goes off and I put the key in the ignition and turn so lights are on dash and the alarm keeps going and I have the padlock come on the dash. The only way I can turn it off is if I put a non remote key that I had cut in timpsons in the ignition.
    Not sure what I'm doing wrong, any suggestions would be a appreciated, as I think the Mrs will go nuts if I've got to fork out on a new key, especially after the oven blew up this week, and have had to get a new one :-((. Thanks in advance, Daz
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    You sure that new battery is working ?
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Found this if it helps.
    http://www.vectra-c.com/forum/showth...attery-Changed
    Quote Originally Posted by Mark-R View Post
    I know its weird but put ya tongue on underside of battery it should tingle lol.
    11 Post(s)
    Having a battery in the fob or not shouldn't make any difference to whether the immobiliser works or not. Its only purpose is for the remote central locking.
    Sounds to me like the immobiliser chip has fell out of the fob when you changed the battery. Unusual though because I thought the chip was attached to the PCB and not separate like in the Vec-B fobs.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by shane31 View Post
    Wrong battery ive tried it LOL
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    your right the chip is on the board
    11 Post(s)
    Not enough voltage in a CR2032
    Try it with a PP3 instead - the tongue test, not try fitting it in your fob
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    BARNSTAPLE
    Quote Originally Posted by vectra ste View Post
    Hi, yeh tried a few 'new' batteries, but hasn't made any difference. I've changed the battery before and didn't have any probs, so now I'm stumped as to what to do next.
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    178 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Hi. I got 2 keys with my VecC recently. One worked fully, the other would only start the car but wouldn't do anything with the remote. The seller assured me that they were the original twin set that came with the car but I was having doubts.
    Anyway having cleaned contacts, changed batteries etc, I resigned myself to the fact that I might eventually need to buy a new key. That was until I bought a certain "tool" from the bay which was supposed to pair new keys as well as other stuff. I ran it, and the keyfob sprang into life again Somewhere along the line, it had become unpaired even though the car would start ok. Anyway, all is well now, so if you know anyone with one of these gadgets, you might want to try that.
  1. Resync your car key
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2010, 02:48
vectra c key fob resync
synchronise vectra c remote
opel vectra 2006 key not working
vectra c key fob sync
vectra c key programming
vauxhall vectra c key fob not working
vectra remote key not working
re synch opel vectra c remote
Astra j resync key
cant synchronise key fob corsa c
vauxhall vectra 2004 remote key not working
vectra remte problem
vectra c keyfob low battery
vectra c key not working
insignia key sync
vauxhall astra 13 sync key
re-syncing car key Vauxhall vectra
vectra c key fob wont resync
vectra c key fob
re-sync car key fob vectra
how to re syn a key fob corsa c
vectra c car key wont work
vectra c programing key fob to car
vectra c key fob programming remote
