Thread: Help!!!! A few issues with my Vectra
    Sep 2012
    Default Help!!!! A few issues with my Vectra
    Hey guys...I have a few issues with my Vec-C and would like some help please. I drive a 2004 Vectra 1.8 club (Engine type: Z18XE).
    1. The low engine oil light is on (orange light). Comes on after a few miles and stays on until I switch off the engine. I checked the oil and it is at maximum. No leaks as far as I can see. Everything else works. Engine temp is normal and the car runs smoothly. The oil pressure light has never come on.
    2. I have a problem with the cruise control. When I switch it on, it stays on but sometimes it switches itself off. Also when it is on and I indicate to change lanes it switches off. (annoying little thing).
    3. My CD is stuck in the CD player. When I press the eject button, I get an error on the display.
    Any help would be highly appreciated. Thankyou.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Number 1 sounds like your oil pump. Does it go off if you rev high?
    Sep 2012
    Quote Originally Posted by Yugguy View Post
    To be honest I don't know. I've not revved the car all the way but the most I've got to was about 4k revs. I will check when I drive it and get back to you on that one.
    Regular Member John Bishop's Avatar
    Oct 2010
    Search cruise control. Could be the contacts need cleaning. There is a How2 on here
    Sep 2012
    Quote Originally Posted by John Bishop View Post
    Thanks for that. I will have a look around.
    11 Post(s)
    It's not the OPs oil pressure light that's coming on, it's the oil level light.
    Jun 2011
    wolverhampton
    I'd say that the level sensor is faulty as I've seen this exact fault before. Clean ya cruise stalk and ya cd will need a yank out with a special tool that I use at work which is basically a thin piece of very strong wire 3mm thick with 3mm long 90 degree bend on the end. But do that at your own risk. We normally get people put two CDs in somehow which jams everything up as you would imagine
  1. vectra c 1.8 sri running issues
    By daddycool in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2011, 16:42
  2. issues with my vectra dti
    By thugusher in forum Engine & Drivetrain
    Last Post: 15th August 2011, 22:35
  3. issues with vectra
    By vectra junkie in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2008, 00:46
  4. Minor issues with my new Vectra GSI
    By RoddyKFC in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 16:55
  5. Various Issues Vectra 2.0 DTI
    By jmacp in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2007, 22:09
