Results 1 to 10 of 22
Thread: Help Please Again !
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Help Please Again !
    signum 2.8 turbo
    cranks over perfect in the morning
    but will not tick over !
    for a few minutes it judders ,shakes bad
    if you try to pull away you dont have no throttle or drive
    after that few minutes it clears and you can drive off
    yesterday morning it even stalled with the engine management light flashing
    also judders at high boost ( dont know if thats related though )
    keep getting codes
    P0090 fuel pressure control circuit
    P0170 fuel trim malfunction bank 1
    i think personally its a fuel problem
    but i dont know what to check
    have changed the fuel filter and put some injector cleaner in
    anybody got any ideas please ?
    Mar 2011
    Northamptonshire
    Anybody Please !
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Probably your fuel pressure regulator on the pump. May be the fuel pressure sensor on the fuel rail.
    Mar 2011
    Northamptonshire
    Ian
    have you any idea where it is
    and what it looks like ?
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    bud i have 3 old coil packs as you know your more than welcome to try them out i know 1 is faulty so will be a ball ache testing them but that's up-to you but try the rear bank first
    its the idling and juddering that i would think coil packs as i changed mine and its all good so fingers crossed could just be your coils but the error suggest that its not
    Mar 2011
    Northamptonshire
    oh the sensor .i think i have seen that .on the top of the engine
    did not know the regulator was on the fuel pump
    Mar 2011
    Northamptonshire
    i know Baz
    very annoying
    when you said you changed your coils and it worked ok .i thought its got to be that
    but the codes say different
    have not got the money to throw at it
    Mar 2007
    swindon
    well if you dont have the money to chuck at it take my offer of the coil packs i dont want anythink for them just cover the postage and then if anyone else needs them after just forward them on
    it will be a pain testing them but with a bit of time it will tell you if that was the problem gotta be worth a try
    the worst coil to get out is bank 5 top right front 3 are dead easy and the top left and top middle are not to bad
    have you gone on the op user forum and asked on there as they are very helpful
    Mar 2011
    Northamptonshire
    Baz
    what is the website address for the op user forum?
    i will take up your offer for the coils ( thanks for that )
    need to get some balls now to try them ..ha ha
    strip it all down see if i can put it back together again
    let me know what the postage is ,and i will send you that and my address
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you able to view data of fuel pressure eyc?
