Results 1 to 10 of 17
Thread: F23 gearbox on 2.2 petrol?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default F23 gearbox on 2.2 petrol?
    I have a 2.2 petrol 5 speed (Z22SE). Can anyone tell me the gearbox? Is it the F23. Its not very pleasant to use in first and second when cold and have just been given this.
    Field Remedy: 1653
    Subject: F23 transmission - Bad cold shifting behaviour in 1st and 2nd gear Models: Engines: Option: Astra-G 1998...2004,Zafira 1999...2004,Speedster 2001...2004,VX220 2001...2004,Vectra-B 1998...2004,Vectra-C 2002...2004,Signum 2003...2004 All,All,All,All,All,All,All F23 Transmission Complaint: Some customer complain about bad cold shifting behaviour in 1st and 2nd gear. The gearshift mechanism is correctly adjusted and clutch system is bleeded. Cause: Tolerances of toothing of the sliding gear. Production: Introduction of transmission with modified siding gear as of transmission number Gxx03240969 in calendar week 41 / 2003. Remedy:
    In case of customer complaint the sliding gear has to be replaced by
    using the Repair Kit, Partno.: 9201451 / Catalogno.: 16 07 013. There
    is no need to replace the entire transmission. FunctionalGroup: K - Clutch/Transmission Complaint Group: 08 - Hard to operate Trouble Code: None
    My warranty runs out at the end of he month, so do I have the F23 and will it be covered by the warranty?
    Melbourne, Australia
    I can't answer your other questions, but yes, the Z22SE does use the F23 manual transmission.
    yes, the gearbox is covered till the end of year3... go in and try your luck..
    at least if you report it now, you'll have a job number logged, so if it gets worse, they'll be compelled to fix it later under warranty
    N E Somerset
    Are the end of the line pre facelift 'C' 2.2 SRI 5 speed (pre intro of 6 speed) F23 as well (such as mine)? My gearchange is very good in all gears.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Repair kit I assume it a modified gear linkage. Still doesn't sort it I needed a full box replacement.
    Vehicle : SRi
    Mileage : 137000
    Well its going in for its first mot soon, a week before the warranty runs out, so i'm trying to find all warranty fixes on the car before it runs out. I might be just getting paranoid but I'm sure the drivetrain is making a whining noise as well, that's already logged for them to look at.
    Leicester
    2.2 direct only has the F40 6-Speed
    Feb 2006
    Guttedsville
    Slight Hijack here I know, but is there a 6 speeder that's compatible with the 2.2 DTI engine?
    Just curious at the moment.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    How much does the diesel 6-speed 'box cost? i was thinking of a conversion to 6-speed
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Andrew's SRi View Post
    damn it, just got in before me lol
  1. Gearbox Identifcation M32 Petrol or Diesel??
    By bowker in forum Engine & Drivetrain
    Last Post: 28th September 2012, 15:31
  2. Vectra 2.2 petrol elite gearbox whine, I think......
    By pt9091 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 09:41
  3. 1.8 SRi VVTi 06 Petrol gearbox update
    By walkie1973 in forum Engine & Drivetrain
    Last Post: 28th May 2011, 15:44
  4. f40 6 speed gearbox - petrol/diesel
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 10:00
  5. vectra c 2.2elegance petrol auto gearbox problem
    By popinoz in forum Engine & Drivetrain
    Last Post: 21st October 2008, 04:13
6speed on 2.2dti
opel 2.2 dti 6-speed gearbox
What is the gearbox code for a vectra c 2.2 sri petrol 6 speed
cdti astra f23 gearbox problems
