Results 1 to 10 of 13
Thread: Tech 2 programming Towbar
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    Question Tech 2 programming Towbar
    Searched loads, couldnt find the key info I need
    Just fitted my witter plug and play, but need to do the fog light delete etc
    going to be given a tech2 to use at work but as the car cleaner I need a hint or two.
    so any vauxhall techs give me a noddy guide
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Both REar foglight and the reversing light to disable the bulbcheck for them is in the REC. should not take him more than 2 minuts..
    But then he need to add the towbar module to most every other module..
    Sep 2011
    oh great, this is where my car wont start tomorrow once i have finished
    thanks for the info
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    There was a tech 2 guide posted up on here somewhere... I shall see if I can find it somewhere.
    Here is the general gist..
    Modules to program.
    REC (Security code needed)
    DIS
    IPC (Security code needed)
    Modify the variant Configuration settings in the following modules
    REC
    Set Trailer Reversing lamp control to Present
    Set Trailer Fog lamp control to Present
    DIS
    Set Check Control To Present
    Set Towbar To Present
    IPC
    If the module Identifier is "0x0***", then Set Towbar To Present
    If the module Identifier is "0x1***", then No variant coding changes needed
    Someone's bound to ask
    REC = Rear electrical centre - boot fuse box
    DIS = Display
    IPC = Instrument Panel
    Sep 2011
    Well I tried to locate one with no luck - but that means nowt
    Engine : 2.2 Direct
    ive been looking to... cant seem to find it.. maby ill take a picture of mine when i get home.. or find it online..
    Sep 2011
    Quote Originally Posted by Robsey View Post
    Modules to program.
    DIS
    REC
    DIS
    IPC
    DIS = Display
    cool, many thanks
    Engine : 2.2 Direct
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Ooh - I know it looks official, but I wasn't aware of changing code indexes in the Instrument panel and the Display.
    Never seen Towbar electrics as an option for the code index tables,
    but have definately seen it on the last page of variance config tables in Vauxcom for the Display.
    Not had to program the IPC yet, so cannot comment... but would still have thought it was a variance config thing.
    Sep 2011
    forgot to add, didnt get round to doing this yesterday, but just slaved a trailer board on and the basic side, brakes and indicators all worked correctly
  1. Key fob programming ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2016, 05:12
  2. tech 2 req for towbar electrics
    By movianto in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2012, 17:00
  3. tech 2 towbar
    By wirrallad in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2010, 22:37
  4. Tech 2 Programming by area...
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2009, 00:26
  5. tech 2 towbar
    By amos in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2007, 17:31
vauxhall zafira instruments coding index table
programmering vectra c
vauxhall insignia tech 2 add towbar
opel vectra c towbar control module
