Results 1 to 10 of 28
Thread: Day 3 of ownership and problems
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Default Day 3 of ownership and problems
    Onthe test drive it came up with egr fault, so during the week the garage had it and fitted new spring new discs and pads got it mot'd etc... They took egr off to clean it, anyway every time you drove the car and it got upto temperature the spanner light would come on and it still drove fine. Today however no spanner light but I did get the exhaust emissions light which is now on perminately, again the car drives fine. When I got to work I did the pedal test to get the codes stored and they showed as egr, particulate filter and misfire cylinder 1. Sorry I couldn't remember the codes. The drive home was good however the idle is really really rough, the car shakes but rpm is steady! I have to add it doesn't go into limp home mode. Also I filled it up at tesco.
    Thankfully the car is of course covered under warranty and it is going back to the dealer I bought it off, they did offer to keep it another week but I don't think I had another day use out off my mgzt, so needed it. The garage recommended I drive it for a couple of weeks to see what happens then give it back to them for a few days. It drives great, plenty of power really smooth, handles fantastically returns over 40mpg on motoway at 75mph. but I can't help being worried sick about it, do I need to get over my paranoid state having owned an mg rover for the last year?
    My car is a 55 reg 3.0v6 cdti Sri.
    Feb 2011
    Worcester
    Thinking back to the drive, with the rough idle the mpg reading was poor so might have been going through a regen! Problem is if the egr is goosed will my car be trying to permanently regen the dpf?
    Feb 2011
    Worcester
    Day 4 of driving car has lost a lot of power, still accelerates but doesn't feel as if turbo kicking in.
    did the pedal test again, my codes are:
    p0409 egr
    p0520 oil pressure sensor, new tonight
    p1901 particulate filter
    p0301 misfire cylinder 1
    when I drove to work this morning it felt like car was doing a regen on motorway, then I accelerated and saw a puff of smoke behind me. The drive home was great mpg was better and car felt smoother. Then went shopping tonight and gave my wife the chance to drive the car, she loved the handling but there was no power when flooring it!
    once pulled into the drive the revs climbed to just under 1000rpm mpg was fluctuating between 0.2 and 0.3 temperature was steady at 85
    how many of those codes could be linked? Or do the garage need to concentrate on each one separately?
    Feb 2011
    Worcester
    Going back to garage on saturday, if a mod reads this please feel free to delete this thread! As I believe thereis no one on the forum who could help me with this!
    Just seen this , is the engine z30dt or a y30dt
    The egr valve on the v6 isn't cleanable.like the 1.9 version so it.needs a.new one
    Not sure if your v6 has the dpf mine hasn't got one if it does have then tech2 can be used to force a regen on them
    Was the big puff of smoke out of the back black , if it was its quite normal for this to happens under hard acceleration it's basically clearing all the crap out of the egr and exhaust as they do get clogged up if not given an Italian tune up.every now and then
    If I was you I would be taking it back and demanding they fixed it all and gave you a courtesy car till it's all repaired
    Sent from my GT-I9300 using Forum Runner
    Feb 2011
    Worcester
    Cheers mate! The garage are taking it back in and giving me a courtesy car till they sort it I think it's a z30dt as its a 55 facelift!
    Quote Originally Posted by marktaylor View Post
    The EGR Valve on the Y30DT engine cannot be cleaned, unlike the Z30DT which can be
    As a 55 reg, it is most likely a Z30DT
    However, could the OP advise whether it has square headlamps and sweeping ones; this will confirm what engine is fitted
    http://www.vectra-c.com/forum/archiv.../t-167391.html
    Might want to check this post if you think the egr on the z30dt can be cleaned
    Especially seeing as you wrote the post m8internet !!!!!!
    I believe that's what they call an EPIC FAIL
    Some changes since June 2012
    The EGR Valve on the Z30DT can now be removed and cleaned (3 days out of car)
    The dealership I use also advise that a procedure for the cleaning of the EGR Valve on the Y30DT is due by the end of the year
    Feb 2011
    Worcester
    Cheers fellas! The garage is ordering a new EGR valve for me and I'm taking the car back to them on Saturday. It's definitely a facelift, there going to keep it till its 100 percent.
  1. 6 & 1/2 yrs of happy Vec ownership about to end
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 20:17
  2. HI all, new to vec c ownership
    By steptoe in forum Introduce yourself.
    Last Post: 1st February 2011, 09:39
  3. VXR Cost of Ownership
    By Vauxhall Thru & Thru in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2009, 20:42
  4. day one of GSi ownership not going well at all
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 16:02
  5. Cost of ownership
    By David2452 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 14:27
