Thread: throttle judder at low revs
    Sep 2012
    Fareham
    Default throttle judder at low revs
    hi bought a 54 plate 1.9 cdti vectra c and having a problem with a slight throttle juddering at low revs but its fine at tick over and fine if i put my foot down it only if its between 1000-2000 rpm at half throttle cruising or if im moving slowly like round a roundabout, i did find one of the hoses from the intercooler up to the top of the block was loose so tightened that up but its still happening please help.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Aug 2012
    If not as above then check your vacuum and air inlet pipes for damage, collapse or splits.
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Found this video which shows how to clean and where your throttle body is
    http://www.youtube.com/watch?v=nilcMVYP2zE
  1. Splutter at partial throttle and low revs on cdti 120
    By Gee-dub-ya in forum Engine & Drivetrain
    Last Post: 21st February 2013, 16:47
  2. vectra c 1.9 cdti 120 diesel judder at around 2000 revs
    By mozzer in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2012, 16:14
  3. Replies: 43
    Last Post: 8th June 2011, 21:03
  4. Judder at 2k revs
    By scottymf in forum Engine & Drivetrain
    Last Post: 28th January 2008, 13:49
  5. Engine Judder 2.0 DTI at 2000 revs
    By cp123 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 17:38
vauxhall vectra juddering low revs
vauxhall astra judders at low revs
vectra c juddering problem
insignia cdti splutters
diesel juddering at low revs
vectra diesel judder at 2000 revs
insignia juddering at low revs
vectra has low revs
petrol vectra has low revs
vectra cdti juddering at 1800 rpm
zafira juddering under 1000 revs
vectra 1.9 cdti judder
juddering insignia diesel
vectra diesel juddering
vectra 1.9cdti splutters at 2000rpm
diesel engine judder at low revs vectra c
vectra c 1.9 juddering at low revs
diesel engine judder at low revs vauxhall
vectra c 1.9 cdti juddering at low revs
vauxhall vectra 1.9cdti throttle response slow between 1000 and 2000 rpm
vectra c juddering
corsa 12 valve judder between 1000 and 2000 rpm
uneven at low revs vectra diesel
vectra tdci juddering low revs
vectra juddering 3000 rpm
