Thread: help!!!!!please
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default help!!!!!please
    could a knackered cat converter put my veccy in limp mode and make diagnostic reading say boost pressure fault?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    anyone????
    Regular Member Phil881's Avatar
    Sep 2012
    Edinburgh
    Sorry, can't answer your question but I have had two cars (not Vecs) that have had collapsed cats, it blocked the exhaust and severly restricted the power of the engine so I would presume the same thing on a Vec would cause some sort of error code.
    Sorry I can't be more help. hopefully someone else with better knowledge will be along soon.
    Good luck
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    thanks Phil.
    Aug 2012
    Have you pulled the pipes off the turbo and checked the turbine spins nice and does not wobble. I would imagine the error you have could be caused by a lot of things but things to check would be - turbo, vac lines, vac solenoid, vac controller (on the back of the engine), boost sensor, pipework from turbo to intercooler and intercooler to throttlebody, EGR, and maybe but hopefully not the ECU.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Ive checked everytging mate.im putting it down ro electrical fault.im starting to give up.
    Aug 2012
    Quote Originally Posted by dazza2393 View Post
    I know how you feel mate. My problem on my old car turned out to be the ECU so all the error codes and weird behavior were all red herrings and it was all down to the ECU. Hope you sort it
