Results 1 to 3 of 3
Thread: 4 Or 6 Pot Calipers
    Default 4 Or 6 Pot Calipers
    Hi Guys,
    I currently have 345mm VXR brakes fitted to my SRi. I'm looking at ways to reduce weight of the brake set-up. One thing I noticed when I bought this set-up is how heavy and pointless the calipers seem. Does anyone know where I can get some lightweight 4 or 6 pot calipers to fit the standard 345mm discs?
    Cheers for any advice.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Spoons is the only one I can think of that's gone down this route. Check out some of his threads.
    South east
    No one's changed to 4 or 6 cylinder calipers and kept the same disks, not even Spoons. You'll need to change your whole set up - calipers, carriers, disks and pads. Here's one option that will fit the Vectra, obviously many others are also available:
    http://www.neobrothers.co.uk/perform...hb0q92oke74dq4
  1. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  2. calipers
    By daddyjay in forum Parts for sale
    Last Post: 26th March 2011, 18:20
  3. are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    By gazturbo in forum Handling & Braking
    Last Post: 5th May 2010, 19:11
  4. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
