Results 1 to 10 of 26
Thread: new egr fittment does this need programing in to ecu
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Default new egr fittment does this need programing in to ecu
    im looking at replacing my egr valve on my 1.9cdti 8v 56 vec after i had a exhaust emmision light, a fellow member read the faulst code for and was an open circuit on the egr, once i replace the valve do i need to reprograme the valve to the cars ecu or fit and go
    craig
    East Ayrshire
    Trim : SRI XP1
    never had to do it on mine
    Aug 2012
    I think it will be fit and go, but I would look at google for ways to test it before buying a new one to make sure its not a wiring issue!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Open circuit fault have you confirmed wiring an plug are ok before splashing out?
    Apr 2006
    no how do i go about checking that out critch and what would i need to do if it was the plug or the wiring?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Do you own a or able to get hold of a multimeter or a test light?
    need to check power an ground ecu control
    Apr 2006
    yeah got a multimeter from work tips/advice on what i need to conect to check ?????
    hull
    Cleaned mine out (both sides) runs like a dream now.(57reg)
    Apr 2006
    yeah ive cleaned mine no and again and had no issues ive checked the connecter to the egr and its fully locked on ?????
  1. Key Fob programing?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2012, 10:24
  2. AUX in on CD70 programing
    Last Post: 18th September 2011, 12:01
  3. Problem with BCM programing
    By Agolubovic78 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2011, 09:08
  4. Programing issues!
    By colalowe in forum Comedy & Humour
    Last Post: 11th March 2010, 01:28
  5. key programing
    By johnturbo in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 10:53
does a vectra disel egr vavle need programing
