Results 1 to 3 of 3
Thread: signum suspension
    Sep 2012
    cheshire
    Default signum suspension
    hi, i no similar threads are there but is the signum suspension the same as the vectra c estate or is it just springs that are the same? ive just purchased a signum with uneven springs on the rear so i need the right one going on but id rather get lowering springs and now iv come across a second hand set of shocks and springs that say will fit but i think the axle weights are different, help please
    Sep 2012
    Far out
    If you want to work on your springs/shocks do keep in mind that the balance and roadholding of the car is made up by matching front and rear properties to the comfort/performance/styling compromise you desire. May likely involve adjustments to wheel alignment etc. as well.
    Of course the standard setup is what the engineers decided was best, but you're free to challenge that any time
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    5 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, the axles weights are different, but for instance, Eibach uses the same part numbers for Signum and Estate.
    If this can help...
  1. signum suspension arm
    By viper8 in forum Handling & Braking
    Last Post: 23rd December 2011, 10:44
  2. Help - Signum suspension?!
    By TIMMAH in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2007, 20:52
  3. Signum Suspension Question
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2007, 20:08
https:www.vectra-c.comforumshowthread.php172477-signum-suspension
