Results 1 to 10 of 11
Thread: Rear interior light problems
    Jun 2011
    wolverhampton
    Default Rear interior light problems
    Hi guys
    Fitted rear light today with STD loom no problems. I have led bulbs in front so fitted same bulbs in rear but sometimes when doors open all the lights will go out and I hear a relay click in the front then they will come back on againfew seconds later randomly as if I have short. Put standard bulbs in and all is fine and swopped front and rear bulbs over but only happens if LEDs are in the back. Thinking of soldering the terminals. Anyone else had this issue. As don't want to short any modules out. Cheers guys
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I had the same problem. Normal lights in there and no problem at all. Put in led bulbs and either didn't work at all but if I moved them they would light up and short out the front.
    I ended up removing the light controlls (out of the lense) completely and put two x12 led blue boards in there instead and thats been working a treat.
    Filled the middle hole (where the switches used to be) with some perpex cut to size.
    These are what I fitted. Just the right size too.
    http://www.ebay.co.uk/itm/Blue-12-SM...item43ae173a6c
    Jun 2011
    wolverhampton
    That's exactly the issues I'm having. I'd like to keep the controls though tbh as they will be handy to have one side on with the new baby. To keep an eye on him at night as the rears are dark tinted so may see if I can find smaller options but similar. Thanks loads for your reply
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Good luck with it mate and my pleasure.
    Jun 2011
    wolverhampton
    Just found a 6 SMD White panel so have a measure tomorrow and will be ordering two of those If I can squeeze them in
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    If you need any help with it give me a shout.
    Just to warn you though it will be like daylight when you switch them on in the dark :-)
    I will remove my light housing tomorrow and take a few pics so you can see what I have done.
    Jun 2011
    wolverhampton
    That would be awesome thanks very much. Much appreciated again
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi Mate
    As promised a couple of pics of mine.
    Just to note that I dremeled the sides down so the pads would fit in snug and low in the lense.
    Then run a few drops of super glue round the edges of the leds pads where its meets the plastic.
    Don't use too much though as it will eat the pads and kill them.
    Chris
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    i had this problem , the metal bit that clips on after fitting the led bulb thingy has a sticky out bit that touches the circiut board on the led thing on mine so i just bent the metal bit flat problem solved.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by montyfert View Post
    Intersting. Do you have any pics of what you did?
  1. Rear interior light
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 17:16
  2. Can't take out rear interior light
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2012, 16:48
  3. Rear interior light
    By SRIcdti205 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 11:18
  4. Rear Interior Light
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2006, 19:25
  5. Rear interior light
    By ed taylor in forum General Chat
    Last Post: 16th April 2006, 14:10
rear interior led lights vectra site:www.vectra-c.com
