Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: bypass limpmode???
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default bypass limpmode???
    hi.does anyone know how to bypass limpmode?also does anyone know how to lengthen the turbo actuator rod so less pressure is required?thanks
    Engine : 1.9 CDTi
    Fix the problem causing it lol
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    cant mate.easier said than done!!!look at all the threads ive put on?????cant fix it mate.constantly in limp mode,renewed boost sensor,egr,cleaned inlet..checked pipes.....im at my wittsend with it lee......what could it be?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    lol
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Have you actually had it checked and diagnosed or just throwing parts at?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    it comes up with fault code p0243...boost pressure sensor...renewed it brand new mate...
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Have you confirmed waste operation?
    have you tested boost sensor to confirm ecu is reading correctly? Apply a vacuum whilst watching live data
    MAP & TPS should read same at wide open throttle.
    so if ecu sees a difference I either one it can throw up a fault.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    whats TPS Critch?
    Engine : 1.9 CDTi
    Throttle position sensor
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    aint that another name for boost pressure sensor or MAP sensor?
  1. egr bypass thought
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2012, 12:17
  2. CanBus bypass
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 08:58
  3. 150cdti EGR bypass.
    By mally in forum Diesel Engine related
    Last Post: 14th April 2011, 00:18
  4. Red SRI Farnham bypass
    By bigboynigs in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 22nd May 2010, 13:46
how to bypass limp mode vectra c
