Hi all
As the rubbish weather is on its way I want to fit Hids to my fogs. Vec is a 06 Facelift.
Fitting won't be a problem but before I start can you tell or show me where you have put your ballasts.
Thanks very much
Chris
Hi all
Thanks very much
Chris
i used double sided sticky tape and stuck them the tray. yours might not have the black tray though.
Thanks for that mate. I didn't even think of putting them there.
I do have the black tray underneath where the four push clips fit in.
Should be enough room but Im going to pull the front off tomorrow and have a good look.
Thanks again.
I popped the headlights out and fitted the ballast in the wing gap and the cancellors underneith the in the same area... No pics tho sorry.
Misread the post sorry....
Going to go with the idea of putting them on the underside tray maybe in some plastic containers to keep them protected. Thanks for you comment though mate.
Really liking your undercar led project so far
I had no idea what you wrote so I would not worry lol
This is where i fitted mine
hth
i had mine on the top of the fogs but they where holding water inbetween the light and ballast so relocated them to the sides of the crumple zone/cross member mount.
i used cable ties to hold them on the sides with the wire pointing down.
Thanks very much lads for your input.
It's given me food for thought that's for sure.
Going to remove the front bumper tomorrow to have a good look at my options, which now I have a few (Had none when I started this thread)
Cheers
