Results 1 to 10 of 15
Thread: Help me PLEASE!!!!
    Aug 2012
    Aberdeen
    Default Help me PLEASE!!!!
    Following the usual symptoms of a failed thermostat on my vectra (z18xer) I have purchased and fitted a new thermostat. I have run water through it to make sure no leaks but the part of the engine it the thermostat bolts onto has now cracked and started leaking. All I need to know is how best to patch this and what is the likely £ damage to be!! I am gutted.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are you able to get a picture of it?
    you may be able to get some metal putty or e metal type stuff to seal it. Or it may need to be welded.
    How has it cracked?
    Aug 2012
    Aberdeen
    I assume I must have over tightened the bolt but I am concerned if the parties that fragile. Will try to take a photo of it. It doesn't appear to be metal like the engine.
    Aug 2012
    Aberdeen
    This is a photo. The thermostat is not connected here and the crack is the black mark on the brown casing.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    You may get away with sealing it with some metal putty can be bought from a motor fafactors how ever doesn't looked like a crack from over tightening
    has it been hit with anything?
    Aug 2012
    Aberdeen
    No not that i'm awar of. Just took the olf thermostat off and put the new one on! Thanks for that, will have to get in the wifes car and fo and buy some.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    can this part not be replaced ??
    Aug 2012
    Aberdeen
    I hope so!!
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Hello mate,did you replace the seal,i think that there is an o-ring in there somewhere--someone might tell me i'm right, i had mine done not so long ago.----Dave
    Aug 2012
    Aberdeen
    Seal and everything were there butthe casing hasa definate crack. Dont even know what its made from.
