Results 1 to 10 of 20
Thread: need help please
    Regular Member cbvectra's Avatar
    Sep 2012
    ripley
    Default need help please
    Hi I'm new to the site but not to vectra this is my seventh.
    I have a 2.2 direct Sri 05 plate. The spanner light came on and the engine would cut out my mechanic said it is fuel related so we have changed so far
    in tank fuel pump
    fuel filter
    air filter
    oil
    plugs
    Injecter wiring loom
    high pressure fuel pump
    swirl flaps
    swirl flap motor
    and it is still doing the same can anyone help as my mechanic is at a loss and it is costing me a fortune.
    Cheers Chris
    Regular Member John Bishop's Avatar
    Oct 2010
    Has he connected a code reader or is it his guess work?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds more like he's doing a bit of part swapping in the hope that it solves problem.
    When does the fault happen? After a particular speed/ rev range? Certain temps etc?
    what equipment has he used to diagnose fault?
    Sep 2012
    ripley
    Its kind of constant thought we had cracked it the other day left it idling then it just cut out. Took it for a drive and got about 500 yards before the spanner came on the it cut out and wouldn't start for a while He has used a diagnostic machine and it says fuel pressure sensor and something about cambus. When we first started have problems it said fuel pressure sensor reading to low changed the h p fuel pump now says too high. He said he doesn't believe it to be a sensor. I really need some advice on this.
    Nov 2009
    newcastle
    Crankshaft sensor. May not show as a fault on a diagnostic but swop this. Also get latest vx software as it doesn't recognise most items. Think latest major is 07 which is what I've got put on and now much better at fault finding and tuning
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    What was canbus fault?
    i would suggest crank sensor too
    Sep 2012
    ripley
    He just said that it keeps coming up canbus.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Try find actual code an what tests he's performed because if its canbus communication fault no amount of parts is going to fix it
    Sep 2012
    ripley
    Why? What is it?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It could be broken wires or a control unit fault.
    best confirming canbus integrity before throwing any further money at it
