Thread: Heater Fan
    Sep 2012
    Bristol
    Default Heater Fan
    Could someone please help.
    My fan only works on setting 4. I have looked through this forum looking for answers.
    I have changed the resistor pack and pollen filter (clearing drain etc)
    I have seen a few people mention the relay switch. I have found where these are under glove box but which one is it.
    There is a brown and a blue (brown one is above the blue) that should be replaced. The brown one clicks when i change fan setting from 3 to 4.
    Any help would be appreciated.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Could be that the thermal fuse has gone even if you have replaced the resistor pack (it has been known for them to be defective even if new) - is your fan spinning ok on no 4 setting - could be that the fan motor shaft is binding / tight and blew the thermal fuse as soon as you switched the motor on. Remove the pollen filter and you should be able to reach in and spin the plastic fan by hand and see if it turns freely. To replace the thermal fuse is easy http://www.vectra-c.com/forum/showth...n-resistor-fix and there is also another how2 to lubricate the lower motor bearing that is more difficult to access
    Sep 2012
    Bristol
    fan spins freely.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    I would be looking at the thermal fuse then on the resistor pack - sounds like classic symptoms
    Sep 2012
    Bristol
    I will give it another go.
    Sep 2012
    Bristol
    could the relay have something to do with it?
    again, which relay? Brown or blue?
    Sep 2012
    Bristol
    All sorted. Bought a thermal fuse from maplins and soldered it on to the OEM part that I bought off ebay. Noticed that the fuse on this part was only rated to 205c and not 240c. It also had different slots but after a bit of jigging all good.
  1. no hot air out of heater. please help!!!
    By jonny22 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 14:22
  2. Heater fan
    By ibbo in forum Bodywork & Interior
    Last Post: 22nd September 2011, 20:19
  3. heater
    By keith_johnson1967 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 22:30
  4. heater is on way out i think
    By dan1983 in forum Bodywork & Interior
    Last Post: 30th January 2010, 13:53
  5. pre-heater
    By andrew m in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2008, 21:51
