Results 1 to 10 of 18
Thread: What ECU have mine Vectra 1,9CDTI EDC16C9 or EDC16C39
    Mar 2011
    Bulgaria
    Default What ECU have mine Vectra 1,9CDTI EDC16C9 or EDC16C39
    I have Opel Vectra c 1.9cdti 2005 automatic with DPF and addon heater.
    How can I find if my ECU is EDC16C9 or EDC16C39?
    from OP-COM:
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x075D
    VIN: W0L0ZCF6851089095
    System name: Z19DTH
    Hardware number:81011616
    Part Number:55197150
    Software version number: WJOAS150_S
    Hardware manufacturer number: 0281012534
    System description: 1037A50284P319_O90
    System description: BOSCH0100
    Type approval number: B05010
    Hardware key number: H000004934
    Programming Date: 20070723
    System description: 0x00006094
    Alpha code: AD
    Software version: O90JTD75
    ECU variant coding: 0x0000FBC0"
    Identifier: 0x075D
    Motor type: Z19DTH
    Software Number: 1037A50284P319_O90
    Variant programming: 0x00006094
    Alpha code: AD
    Hardware manufacturer system name: EDC16
    Admin plasma's Avatar
    On the Forum
    309 Post(s)
    Engine : 150
    Mileage : 74000
    the C9's were upto 05 and 55 onwards were the C39's also there is the odd exception
    with DPF = C39 for sure
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Edc16c39 is a full read c9 is partial u have a 39 mate
    Mar 2011
    Bulgaria
    Thanks for assistance! Appreciate!
    p.s
    I was hoping to hear something like that: "with DPF = C39 for sure"
    Mar 2011
    Bulgaria
    I just receive respond on ebay by "powergate" seller.
    "Sorry but your car is equipped with edc16c9 and you can't read it by obd connector you have to read by k-tag and only after you can write it with kessv2 by obd"
    How can I check what is my ECU?
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    You carnt write a c9 with a kessv2 it will brick it trust me you need somet like a superchips tuning tools Wich will only take a practical read the kess does full read on both I you full read it map it it will brick it !!!!
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Just had a look propaly your car is c9 as the eBay man said who ever it is if ya trying to map ya car you can do it thought odb just have to no how with out bricking it and you deffo don't use a kess to map as I said earlyer it will kill it use somet else
    South east
    Quote Originally Posted by paulvectrac View Post
    Something tells me the phrase "brick it" isn't one that's used or understood in Bulgaria, which is where the OP is from.
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Arrrr lol your probably correct brick it means loose it then you have to bdm it or have tech 2 to get the ori file back
    Mar 2011
    Bulgaria
    Quote Originally Posted by Rebellion View Post
    well understood, however thanks m8
    reply from seller "Yes i am sure! With hw and sw number i can check what type of ecu you have"
    And from another forum:
    "According to Bosch number => EDC 16C9-3.11. There are tools that can do this ECU over OBD. Byteshooter can handle it."
    Bosch ESI say - EDC16C9-3.11 MPPS can read and write this ecu, but partial only."
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. Astra 1.9cdti 16v no boost at all - not mine
    By dh.dti in forum Diesel Engine related
    Last Post: 29th June 2012, 20:59
  3. Irmi front bumper skirt...MINE MINE MINE
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2009, 22:07
whats the difference edc16c39 and c9
Bosch EDC16C9 c39
edc16c39 kess
bosch edc16c9 or 16c39
read edc16c9
edc16c9 or c39
kess v2 vauxhall edc16c39
diesel credc16c9
remapping egr on a edc16c39
vectra diagram ecu ktag
edc16c39 and edc16c9
edc16c39 bricked
EDC16C9 remap
edc16c9
vectra ecu 55197150
edc16c39
edc16c39 engine electrical system wiring diagram
