Thread: Grrr Damn astra gear stick
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default Grrr Damn astra gear stick
    i just stripped my car out to fit the astra gear stick (5 gear one) the damn thing didnt fit and once i got it in place it wouldn't go into reverse grrrr
    Has anyone else fitted one to there GSI
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I got it to fit and work put the old one in reverse took it out put new one in reverse bolted it down clipped the cables in place and all fine now
    Regular Member mrk's Avatar
    14:88 our time will come
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    how did you get the old one out is it just brute force,got mine to fit next week
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    The 5 gear one is totally different from the 6 gear one it doesn't split at the ball so i had to strip the full center section out take the arm rest and that out first then the big bit around the gear stick.
    but if you have the one that splits at the ball your laughing cos you wont have to change the full thing just split it at the ball unclip the cables and swap over.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    oo and the astra 5 gear one is shorter at the base where the cables clip into i had a old stick from the old car so i cut that up and put the bit the cables clip into on the astra one lol
    Trim : improving
    Year : 06
    hopefully the astra vxr one i've got just drops in then,fingers crossed.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Have a look and see if it has got 4 torx screws around where the ball joint is if it does it will be a straight swap
    Trim : improving
    Year : 06
    yep x4torqs just unsure about splitting the balljoint,don't want to break anything
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Na you wont its all stuck together its only the base that comes away
  1. Astra gear stick
    By dilan in forum Styling
    Last Post: 19th July 2012, 13:20
  2. astra gear stick help
    Last Post: 24th March 2012, 16:52
  3. My XP2 with Astra gear stick
    By Mopar Man in forum Quick Photo Album
    Last Post: 21st March 2012, 19:51
  4. astra gear stick
    By marc vectra sri in forum Styling
    Last Post: 12th March 2012, 18:24
  5. Will an astra h gear stick fit?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2010, 17:30
