Results 1 to 2 of 2
Thread: Weird Heater Fan Problem
    Regular Member Bethan39's Avatar
    South Wales
    confused Weird Heater Fan Problem
    I normally leave my heater fan on number 1 so i can have cold air blowing into the car (except when the wife drives it and she always turns it off) anyway i've noticed now if i turn the fan off it still is on at number 1 speed? all the other speeds work fine there is no difference in the fan being off or turned on at number 1 but 2,3,4 all work as normal i guess it could be the resistor? what do you guys think thanks
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    If you've got the aircon on, the fan doesn't turn off until you turn off the aircon. It could be one of the microswitches inside the heater controls. There is one to turn the fan off & one to turn the fan on full. There is a lobe on the fan speed dial inside the console which acts on these switches. They are only small & quite flimsy looking tbh. My heater did this & it turned out the switch had pretty much worn away. I had to get a console from a scrappy & swap the switches over.
  1. Weird problem with heater blower only works with the lights off
    By evhop in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 22:02
  2. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 14:29
  3. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  4. Weird Heater Problems - Help Please
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 09:44
  5. Weird screen heater behaviour
    By SignumPhil in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2007, 12:52
