Results 1 to 2 of 2
Thread: Oil Leak - Signum 2.8 V6 Turbo
    Reading
    Default Oil Leak - Signum 2.8 V6 Turbo
    I was planning on giving my car a service tomorrow. Purchased
    - 6 x Spark Plugs
    - 6l Oil
    - Pollen, Air, Oil and Fuel Filters.
    - Sump Plug Washer
    1st question. Vauxhall dealer gave me a plastic sump plug washer which I wasn't expecting? Is that right? Thought it would be copper..
    2nd question. I popped the car onto an axle stand this evening to check I have all the right tools to complete the job tomorrow and noticed an oil leak on the side of the sump. Now I'm a little worried and don't want to waste an oil change if I've got a problem.
    See attached photos. Arrow indicated location of oil in both, the oil appears to run up the side of the sump as far as I can see without a torch.
    Comments, thoughts appreciated. A little nervous.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Pick from up the back or take the little inner wheel arch for a clearer picture. As could be chain casing seal
  1. CDTi (120) Turbo oil leak
    By Casey in forum Engine & Drivetrain
    Last Post: 10th April 2012, 20:40
  2. 2.8 turbo oil leak?
    By 2.8 turbo in forum Engine & Drivetrain
    Last Post: 6th October 2011, 09:04
  3. Small Oil LEak @ Turbo. 2.0L DTI
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:58
  4. cdti turbo oil leak
    By sla002 in forum Engine & Drivetrain
    Last Post: 26th July 2010, 16:04
  5. Possible oil leak from turbo
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 19th February 2010, 19:56
