Results 1 to 10 of 16
Thread: wanting to upgrade screen to GID help plz??
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default wanting to upgrade screen to GID help plz??
    Hi guys looking to upgrade my screen to GID i have a BID i think the one up from the basic one, i have a 08 plate sri, i found a couple of screens on ebay, i think there GID but can they be used as they are pre facelift. the part number is 13117636 AJ
    http://www.ebay.co.uk/itm/VAUXHALL-O...item4846b3bf20
    does it need to be unpaired from the donnor car??
    cheers guys
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    I did a list many years ago for the three "era's" of display - that is
    Half CAN - oct 2002 to sept 2004
    Full CAN pre-facelift - oct 04 to sept 05
    Full CAN facelift - oct 05 to end of production.
    ALL GID's are the same size - it is only the facelift CID that is different - that is a widescreen device.
    You should be looking for one with codes BJ or BK - they are the later GID's with the three line BC format.
    The most common pre-facelift full CAN unit is the display with alpha code DD
    Do not bother with Half-CAN displays.
    Yes - you will need the donor display divorcing and putting into delivery mode (or the donor vehicles car pass number).
    And you will need to divorce your BID from your head-unit.
    You will then need to pair your new GID and head-unit and any other MS CAN devices all at the same time
    That is
    DAB = digital broadcast unit if fitted
    DIS = Display
    EHU = Head-unit
    UHP4 = Bluetooth / telephone portal.
    Then program in any variance config or code index parameters that you need.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Ah thats quite helpfull well ive got rid of my head unit anyway the sound ia crap, but I will be putting a DVD/satnav unit in so I just need a better screen. So the half can is a no go then I just need it for my range and time etc thats all. Ive read I might need to cut wires etc???
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Half CAN display is wired differently, but can work on a full CAN car without the radio.
    Just need to swap your power wires around, and also put in an ignition live feed for pin 4 of the display.
    The green CAN wires should all be the same.
    You will need the BC buttons on the wiper stalk to operate the Board Computer functions on a half CAN display.
    The half CAN display shows more board computer values than the later full CAN displays.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Ah, I think it would be better to use the full can, could I use the full can pre facelift ones??
    So what codes then do I need bj and bk??
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Here is a full list according to EPC4 - these are all suitable for a full CAN Vectra-C
    PRE-FACELIFT
    Part No. = 24461295
    Catalogue No. = 62 36 484
    Description = UNIT, DISPLAY,GRAPHIC INFO - MONOCHROMATIC (IDENT DD)
    Chassis Range = 51000001 to 61999999
    Part No = 13206820
    Catalogue No = 12 36 738
    Description = UNIT, DISPLAY,GRAPHIC INFO - MONOCHROMATIC (IDENT AD)
    (USED WITH CD30 MP3) (No Longer Sold- USE 13265760)
    Chassis Range = 71000001 to 71082921
    Part No = 13265760
    Catalogue No = 12 36 753
    Decription = UNIT, DISPLAY,GRAPHIC INFO - MONOCHROMATIC (IDENT AL)
    Chassis range = 71082922 to 71999999
    FACELIFT.
    Part No. = 13275277
    Cataloge No. = 12 36 770
    Description = UNIT, DISPLAY,GRAPHIC INFO - MONOCHROMATIC (IDENT BJ and BK)
    Chassis Range 81000001 onward
    PRE or FACELIFT not identified.
    Part No. 13178765
    Catalogue No. = 12 36 727
    Description = UNIT, DISPLAY,GRAPHIC INFO - MONOCHROMATIC (IDENT SD)
    No chassis range given.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Cheers for that rob, just one last question u said about programming the screen to the other devices, so it would be the display as in the GID its self and the head unit?? Sorry im just unsure and want to be clear what to do, ive got op com and done a cpuple of things so I know my way about it.
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Regarding Op-Com - pm sent.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    you were saying about the BC function, would it work if i get a wiper stalk with the buttons, because i would not have the vx headunit in so i would like the BC function for the GID screen.
    my caqr is full CAN 08 plate
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hmm - Steering wheel controls !
    The stalk is for half-CAN displays.
    Are you fitting the steering wheel control adapter for you after-market head-unit?
    If you are, then the BC functions will not respond to the steering wheel controls.
    If you are not fitting the steering wheel adapter loom for the after-market radio, then yes the scroller on the left spoke of the steering wheel will operate the Board Computer functions.
    Press the left scroller to select,
    roll up or down to scroll through the options
    press the scroller to select.
  1. screen upgrade
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 00:28
  2. Screen Upgrade
    By wstwatson in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 09:50
  3. A bit of reading for those wanting to upgrade to sat nav.
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2007, 21:32
  4. Screen upgrade
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2007, 17:52
  5. Screen upgrade
    By Jim Bob in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2007, 12:35
