Thread: CD70 with bluetooth - straight swap?
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default CD70 with bluetooth - straight swap?
    Hi all,
    Is it possible to take out my CD70 and fit a CD70 with a factory fit bluetooth without any issues?
    i.e. pairing, car ecu.....
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Why not just fit the bluetooth module and have it coded in? You would still need to pair the screen to the head unit unless you changed that too.
    Aug 2010
    Pontefract
    its a complete set up ive been offered including the screen for the same price as a cd70 on its own
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    plasma is your man to ask about this..
    Aug 2010
    Pontefract
    Quote Originally Posted by Caveman_nige View Post
    cheers, I'll drop him a pm
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    if youve been offered a cd70 with cid and bluetooth all paired together then just remove ya old cd70 and cid and replace it with the
    1 youve been offered and it will work straight away as its just plug and play.
    theres no programming involved unless you want to just replace the cd70 head unit on its own and then it gets complicated as you
    have to get it all completely divorced from each other then re programmed but this way you also need the correct security codes for each of the setups.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by andy.l View Post
    Agreed - if you get the whole lot from a donor vehicle without it being divorced, then you are good to go.
    If any indevidual item is divorced from the rest, then it is a tech 2 maize.
    Doable but a total ball-ache.
    The only programming you may need will be code index values and variance configs to match things like fuel type, air-con / ecc type, with or without BC and so on.
  1. Tps straight swap?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 14th February 2012, 18:57
  2. cdc40 straight swap
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 23:39
  3. Been offered a straight swap on my vec, what do you think?
    By sri andy in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 11:05
  4. are these a straight swap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 18:43
cd 70 engine swap
