Results 1 to 10 of 16
Thread: Brake and Side Light Problem
    Feb 2012
    Crawley West Sussex
    Default Brake and Side Light Problem
    I have a problem with the second side\brake light on the passenger side, it stays on all the time since the other day when the bulb warning light appeared on the dash. The light stays on even with the ignition switched off. I have a 2.2 DTI vectra on a 53 plate, can anybody point me in the right direction???? I have taken the bulb out, so not to drain the battery. This is my first post sorry if it is in the wrong place.
    The parking light is staying on, this suggests the left hand indicator is activating when you remove the ignition key
    This could be a fault in the CIM module
    Try pushing the indicator up when the iginition is off, then remove the key and compare
    If that doesn't resolve the issue remove the indicator stalk and compare
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it front light on aswel or just rear?
    Quote Originally Posted by Critch View Post
    As the OP has advised, the side lights are both ofthe front parking light
    The parking light option comes on when you press the indictor then remove the key
    This then illuminates the relevant front side light and rear lamp on that side only
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah I know that but he says side/ brake light.
    So I'm trying to work out if it's the side of the car or if it's just the cluster at rear.
    Deoending on what it is will dictate wich approach to take to investigate fault
    Feb 2012
    Crawley West Sussex
    without the ignition key in the second side/brake light on the passenger side come on as soon as i put the bulb in. I have not checked the front light to see if that is on, will check this in the morning.
    This problem only started on the way to work yesterday.
    I read that as both, as in the subject, ie front side lamp (parking light) and rear lamp
    ie, the parking light option is active when the ignition key is removed
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Ok check the front light.
    And report back.
    Feb 2012
    Crawley West Sussex
    I checked the front light this morning and it was not on. The rear light comes on as soon as the bulb is replaced, with the ignition turned off and no keys in. All the other rear and front lights are working correctly.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    You have a short in that rear light.
    try putting that bulb in a pulling other bulbs see if it goes.
    Try wiggling the wires a connector to the light.
    Do you have a test light or multimeter?
  1. LED side light problem
    By SRIRob in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 19:23
  2. mtec side light problem
    By mccluskey119 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2010, 15:45
  3. Side light problem
    By -Rob- in forum Vectra C / Signum Troubleshooting
    Last Post: 8th February 2010, 17:57
  4. Side Repeater/Brake light decals
    By turbohaggis in forum Styling
    Last Post: 16th May 2009, 22:34
  5. Brake light problem
    By dave200 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2009, 01:46
renault scenic brake light works but no side light
