Results 1 to 10 of 14
Thread: help!!!!!please
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default help!!!!!please
    hi.i need some help desperately...ive cleaned the egr valve,cleaned air flow meter..cleaned the inlet manifold of crud..my mate plugged his diagnostic tool in and it came up with fault code p0243.boost pressure sensor.ive just fitted a new boost pressure sensor and it still going in limp mode,it cracks when i rev the engine.the part i have bought was 2nd hand so there is a chance its a duffer.can anyone help?any help would be grateful!!!!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I would stick the old boost sensor back on and see how it goes
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    well its broke tony as it was throwing up fault code p0243 boost pressor sensor,thats why ive bought this one.do you think i should buy a brand new sensor not 2nd hand?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by dazza2393 View Post
    I would start with a thorough clean of the 2nd hand one you've got. Use carb cleaner. If no good then buy brand new
    Alternatively, long shot, but if you know anyone with similar car (same engine), try a swap...
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    i used oven cleaner,would that damage it?
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    I would check boost pipes and use carb cleaner would think oven cleaner may be too corrosive mate
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Big Red View Post
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    where are these boost pipes mate?do you have any pics?
    May 2011
    As you look into engine bay mate you will see i little whit cylinder shape at front right next to battery box they have two hoses coming out of it they tend to crack or when boosting close up due to suction causing said problem so people replace them with silicone hoses there is also a third hose under engine cover on right side it will be in a crescent shapeits about six inches long il look for link
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    thank you lads.any help would be gratefull
