Thread: Where's my oil gone?
    Regular Member adierolfe's Avatar
    Feb 2012
    Corris
    Default Where's my oil gone?
    After having a new turbo fitted 2months back, because the Z20NET was burning it and fubarbed the turbo, the car is still losing oil.
    There are no leaks on the floor or any smoke that I've noticed. I just get the oil light on from a warm start and the oil level is on minimum.
    The car is going from max to min in about 2-300 miles.
    East Midlands
    ?what colour is the exhaust smoke pal,could be burning it.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Does it use any coolant? How many miles on the car?
    Could be a few things, but a litre in 300 miles seems a lot to lose ...
    Regular Member muad_dib77's Avatar
    Ardee Ireland
    Hows your exhaust looking? Bit of blue smoke in there?
    Oops :-) Got beaten to it...
    Check for traces of "mayo" in the cooling system as well..
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Last time I had a car drink oil at this rate (D-reg Austin Metro ), it was head gasket failure. There was very little blue smoke from the exhaust too....
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    intercooler i bet
    Feb 2012
    Corris
    I haven't seen any blue smoke. I'll check the coolant in a bit.
    Ardee Ireland
    Quote Originally Posted by paulvectrac View Post
    intercooler i bet
    As Paul pointed out - check your pipework as well.. could be hiding in there... I would think car would run funny at speed..worth a check tho.
    When did you last have a compression test done?
    Feb 2012
    Corris
    The car runs as it should. But the blue smoke is now back on a cold start for about 10seconds then it goes.
    Could it be the turbo again?
    Ardee Ireland
    I'd guess it's a seal/gasket somewhere - get a compression test done..shouldn't be dear.
    If your turbo came with a warranty you might be able to get it checked FOC..
