Thread: Another 2.2 Dti limp thread
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Default Another 2.2 Dti limp thread
    Hi. I'm having problems with my Dti going into limp mode. I know there are countless other threads about this problem but none of them seem specific to my problem. Sometimes when I accelerate normally through the gears up to motorway speeds, the car will go into limp in either 4th or 5th gears. If I accelerate really gently, it won't go into limp. I've checked all the hoses & everything looks & sounds ok - I can't feel anything blowing anywhere. What is confusing me though, is if I rag the car from say 30mph up to 70mph, its fine. I would have thought if I did have a dodgy hose somewhere harder acceleration would make the problem worse. The only fault code I get is the overboost code (is it p0234?). Has anybody else noticed this?
    Should I be looking at maybe cleaning the turbo or a new boost sensor or should first port of call still be replacement hoses?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi dave
    it may be that all you need to do is to give the boost sensor a clean , but on removal you may find that it is well cruded up then i would recommend you remove the top manifold as well and clean that out as well .
    Just spray the solenoid sensor tip with carburettor cleaner to remove the carbon build up or use a small paint brush to remove the more stubborn build up.
    Dont scrub the tip as it can be easily damaged .
    similarly with the manifold spray the internals with carb cleaner and adgitate with a paint brush to remove the carbon build up then flush out.
    and still loving it
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Cheers bob. I might try a new sensor cos I cleaned it a few weeks ago. I might have damaged it cos I just gave it a good wipe with some bogroll! Do you know if these turbo cleaner kits are any good? I would probably try one if they work but I imagine they are no substitute for giving the manifold a good scrub.
    Engine : 2.0DTi
    Mileage : 73350
    Have a look on e bay for a product called BG244 this is about the best engine cleaner available . you should see a marked inprovement in your cars performance
    and still loving it
  1. 2.2 dti limp and cut out
    By ptrehearn152 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 23:45
  2. Another Limp Home Mode Thread
    By aruffell in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2012, 22:00
  3. DTI limp.
    By madman in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 19:15
  4. It keeps going limp on me!!!
    By Jobbytron in forum Engine & Drivetrain
    Last Post: 2nd February 2008, 20:17
  5. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
2.2 dti limp mode 70mph
