Thread: How would i know if ive got a broken spring ???
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    Default How would i know if ive got a broken spring ???
    Hi guys as the title says every time i go over a bad bump im geting a cloncking noise from the car its sounds like metal to metal clocking together so first thing i thought of was a broken spring so want to get this checked out over the next three days and any help much appreciated as always
    cheers
    Paul
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Best bet is to jack the car up and remove the wheel where the noise is coming from and fully inspect the spring. A break will be easily noticeable with the car jacked up up
    Could be a droplink, bush, track rod end, ball joint..... etc.
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    ok thanks mate will do that tomoz
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by wardy23 View Post
    If you have a broken spring, best changed in pairs, ie both fronts or both rears
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    Quote Originally Posted by tony-1977 View Post
    yeah if there broken im going to drop it on apex lowering springs £89 from larkspeed
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Haha someone else noticed this then!!! Cant wait til payday
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    I had that metal clonking noise over speed bumps in my vec but when I inspected springs they were fine.Also the plastic sleeves where there. It turned out as the drivers side top mount bearing was shot.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    There was a common fault of lose radiator mounts that people thought where the suspension banging
  1. Broken spring-what to do?
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 20:10
  2. broken o/s/f spring
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2009, 21:33
  3. broken spring!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 19:37
  4. Another broken spring...
    By shunter in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 12:31
  5. broken spring
    By toshiba in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2008, 21:57
