Results 1 to 10 of 14
Thread: Water in Drivers side passenger (rear) footwell.
    Sep 2011
    Cambs
    confused Water in Drivers side passenger (rear) footwell.
    Hi guys. Right.... bit of a problem here. I've got a wet rear footwell on the drivers side. The plug near the pollen filter is clear and I've poked and prodded the drain plug on the drivers side near the suspension arm thing (under the same housing as the pollen filter) and there's no water in the front drivers footwell, just the rear. I'm not losing any coolent and the car's fine execpt this wet footwell. Has anyone any ideas...Please.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If it's the rear, it won't be the pollen filter problem or coolant.
    Is there any damage to the door seal on that door? Or (bit of a long shot), is the aerial base tight (as they can leak) ?
    Sep 2011
    Cambs
    The aerial base is tight...Anymore ideas???
    Regular Member Lockstock2012's Avatar
    Aug 2012
    Bristol
    Have you given any old ladies a lift? Is the boot wet - in my short experience of the Vectra I'm astonished at how much water can get in when you open it in the wet - I didn't see 'Swimming Pool' on the features list!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Lockstock2012 View Post
    Sep 2011
    Cambs
    And the plot thickens... There was some water sitting on the door seal and the underside of the door was wet so I removed the interior door panel and as soon as I undid the bottom screws approx 1/4 of a pint of water came flooding out. Any ideas anyone PLEASE.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    There should a drain hole in the bottom of the door which might be blocked with rust or crap
    Sep 2011
    Cambs
    The interior panel itself is soaked on the inside on corner below the handle and is wet all the way to the speaker. And the drain holes are all clear.
    New Member spacy59's Avatar
    Sep 2012
    France
    hello i already have this problem in my car
    the carpet was all wet from the front passenger side in the rear
    it was my evacuation of water under a water trap was clogged.
    Water therefore past the cabin air filter
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by merikiito View Post
    I'd go with this. Small screwdriver or pen knife and go round all doors poking the crap out of the drain slots.
    HTH
  1. water in passenger footwell
    By brynsueg in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:25
  2. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  3. woke up to a massive pudle of water in passenger side footwell
    By danny1992 in forum Bodywork & Interior
    Last Post: 27th February 2011, 15:12
  4. Water in (rear) passenger footwell
    By shoeless79 in forum Bodywork & Interior
    Last Post: 19th March 2010, 00:57
  5. water in passenger footwell
    By Task in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2009, 16:09
water in vectra footwell
water drain vectra c drivers side
2010 astra rear footwell
vectra foot well water rear
vectra driver and rear footwell wet
