Thread: eml on my vxr
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default eml on my vxr
    hi all
    keep getting the EML on before i start the car but soon as its started it turns off after 5 seconds
    i know it is meant to come on for 30 seconds when you turn the ignition on but it never turns off util started
    bit stumped on what it could be i have had a reader on it and only fault it read was u2111 something to do with the power steering but steering it fine and not had any problems with it
    i have been reading on here that it may be worth popping the ABS plug off and giving a clean with WD40 so will try
    i have also checked the battery connection as told that it may be related that but any other suggestion i cold try would be grateful im not the best around the engine so if you could pop a pic up and show the part and description that needs looking at will be a great help
    when it first come on a few weeks ago i disconnect the battery for 15 mins and this cleared it for a few weeks but its back again so could it be as simple as a connection?
    It's Meant to come on with the ignition lights and go off when the car starts , so I can't see the problem you have ?
    Sent from my GT-I9300 using Forum Runner
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Was thinking sane thing :-/
    Mar 2007
    swindon
    when you turn the ignition on it comes on yes but after 30 seconds or so it should turn off as with all the other pre warning lights
    TBH i think it less than 30 seconds as well
    Dec 2011
    Seaham
    Think you need to have codes checked and cleared just for peace of mind. It sounds normal to me.
    Mar 2007
    swindon
    Defo not normal mate
    had codes read as did it myself and also cleared them but the same u2111 comes back every time
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    its not normal fella the light should go off when the dials do there sweep. if it stays on it has logged a fault and the car is making you aware of that. as long as it goes off when the engine is started then the problem isnt present and has just been logged
    you need the codes read bud
    pity you aint closer could have done it for you
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sounds like its saying theirs a stored code then.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by baz2003uk View Post
    U2111 CAN bus no communication with EPS (Electronic Power Steering) C-003
    Mar 2007
    swindon
    i have disconnected the battery again today and its stayed off well until i just used it to pop to the shop and it popped up again under fualt u2111 again and i am unable to delete the code little confusing do you think popping it into a local garage would be worth doing to see if they can see what its all about or will they just get the same fault that i am getting?
