Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: help needed asap
    Mar 2012
    bath
    Default help needed asap
    i have a vectra 2.2 direct on a 54 plate and it is now doing my head in as it has got no power at all it revs to 2500 rpm and will not go any higher i know they suffer with hp problems but i have had this off stripped and rebuilt it it had developed a rattle i found the timing chain was very loose and have now replaced this but not sure if i am one tooth out as i had no cam locking tool to set it so did this by eye. but still have no power so looking for any ideas can any one help please!!!!!!!!!!!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Would start with getting a tool an ensure it's timed correctly before going further
    After that check pump an regulator.
    Aug 2012
    can you not just use appropriate size drill bits to lock cam and crank? Also check Crank and cam sensors :-)
    Mar 2012
    bath
    i have checked the pump and stripped it right down cleaned and rebuilt and refilled with hydrulic fluid does any one know where i can get the tool to lock the cams cheaply
    Mar 2012
    bath
    Any ideas to check can and crank sensor please as I have no warning lights on
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Best way for can an crank sync if with a scope.
    Doagnostoc live data will give you a view of what each sensor sees but it hard to tell sync
    Mar 2012
    bath
    Just checked cam sensor seems ok can't find crank sensor is there anyone local to bath who has a cam locking tool who can help and also if not can any one tell me if the balance chain could cause this problem I am desperate to get the car running right if not I will have to sell it
    Mar 2012
    bath
    just been reading some posts can anyone tell me if the z22yh has swirl flaps and if so are there any pictures of them or does anyone know where they are
    Blantyre
    Quote Originally Posted by martin.lake View Post
    Yeah it has them though I don't have any pics , how long did it take you to do your chain
    Sent from my iPhone 4s using Forum Runner
    Mar 2012
    bath
    i guess if i never stopped it took me about 4-5 hours bare in mind i have done it without any locking tools
  1. help needed asap
    By sristeven1 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 30th January 2013, 20:28
  2. Air box mod help needed asap
    By stokie-lee in forum Petrol Engine related
    Last Post: 19th June 2011, 15:30
  3. help needed asap
    By Slick in forum Photoshop section
    Last Post: 28th June 2009, 14:28
  4. K&N Filter help needed asap !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 17:08
